Hi guys. I was a commissiong technician before I retired. Hardware and software industrial automation. Miss the work but not the endless travel/ airports hotels etc. Those that know, know what I mean.
I retired to Thailand 220 - 240 volt single phase 50 hertz supply here. Im used to 3 phase or 24 volt control supplies.
I need a sanity check/ advice to pass on please.
The amount of shops being supplied from the one government source exceeds the supply. So at 6pm when the lights all come on the guys at the end cant run a microwave and lights flicker.
Im thinking of installing equipment to step the voltage down from variable to steady 110 volts ac and change all the fitttngs to run on 110 volts as USA equipment. I cant think of any reason why not, any thoughts or recommendations welcome.
The supply company will not be improving the system for some time. Thanks in advance
