just want to clear a few things up:
intend to use a generator on a domestic using a manual change over switch (basically if the electricity goes off)
my questions:
1) if generator has floating earth (neutral and earth not connected together), can i rod/spike the generator frame and connect this to the domestic earth to become invariably a TT?
2) if the generator is not floating (n/e connected together) , can this be treated similar to a TNCS (pme) and then just bond the gen frame (without the use of a rod) and have the earth/neutral seperated in the consumer unit?
3) how do you treat in the existing main earth e.g. TN system into the property when usnig a generator, unsafe to disconnect?
any help would be much appreciated, asked a few other local electricians - people seem to be unsure as they don't tend to install them much round my area, or they don't 100 percent know what is truelly correct.
*With the above, i understand the generator supply cable has to be correctly installed / rcd protected possibly/ fused correctly
thank you
my questions:
thank you
