A
AslElectrical
Hi guys , new to the forum I have been given a motor by a friend to see if I can get it working for him , its from a compressor , not sure of the make of the compressor but the motor has a stamped panel on the side which shows all the details , they are as follows
230v , ac , 2.2kw , 2850rpm, 50hz , 1 phase, 15.5amp, frame number: ped90ln. J067462 , class f , ip54 , 9658
I'm a competent electrician but haven't a clue on motors , its come to me with all the wires removed from the top block ,it has 2 capacitors bolted to the side , the wire colors are red blue black orange yellow , I can take a picture of the top block if needed
Any help would be very much appreciated , thanks in advance
Lee
Lee
