230v or 12v | on ElectriciansForums
Discuss 230v or 12v in the Australia area at ElectriciansForums.net
G
Guybrows
Hi Guys
I am going to install some track lighting in a pub. I was wondering what the pros and cons are for 230v halogen fittings and 12v halogen fittings. Seen some really good 230v tracks that will work really well but im a bit concerned that they will gobble up electricity.
Thanking you
Guybrows
I use 5W Eye-lite LED GU10 lamps ,It's the equivalent of a 40w halogen, the light is even the same shade as a halogen. They dim really smoothly as well.
night club with over 200 inset lights all fitted with led lamps. they cost nothing to run and I have not had to change many at all in two years all gu10. how many jobs have I been to where the plank had left the tranny to near the fitting up to the loft we go green melted plastic everywhere joist black as shoe pollish.
Hi Guys
Thanking you
Guybrows
Yes go for 230v because of the lack of need for transformers and also because the fittings themselves will be larger and more suitable for a pub. I would not recommend LED's though, too expensive for too little light!.
Our single circuit HV1 is top quality, long lasting and inexpensive.
Reply to 230v or 12v in the Australia area at ElectriciansForums.net
As littlespark says there's no ways you're going to find spike lights that can accomodate SWA cables directly into them.
Thanks for you response, that makes more sense LEDs do produce less heat. I think i read somewhere that LEDs are more sensitive to heat, as in...
