ive got my am2 in april, will that include the amendment do you think or not?
im curious if im honest because it wil mean getting more new books to study if it is (changes to the wording in the regs and cmin etc)
any advice would be appreciated
If it is. Circuits and containment are already designed for you.
Books will be available (they were at the college I sent my apprentices) for the written side of the test and verifying your test results.
My personal thoughts on the new AM2 is it's a joke. From your input the forum, you'll walk it.
im not even thinking about the practical to be honest, im more interested in the theory side.
i do a lot of sy and swa at work so im not worried about that
hope you use this (pic) before. good luck
if you think that the installation part is easy, then you are wrong. one simple mistake e.g. missing a tie wrap or the FP200 cable in the same entry bush with other power cable.
theory is easy, open book online multiple choices. cant go wrong if you done 17th before.
the AM2 is really strict, alway little silly things cought you up. good luck anyway
The am2 practical is a peice of p!ss. An you shouldn't be using cable ties with the SWA or fp200, cleats and p-clips are what are required in the exam.
Shanky my can you follow a dot to dot. If yes you've passed.
most colleges I viewed even had demonstration boards set up in how it should be done. They were used for the fault finding section.
he means tywraps on the rj45/ethernet/cat5 point you have to do.
your supposed to tywrap it to them when you punch them down with a krone tool
Contrary to popular belief, it is easy to fail on tiny, minor mistakes that you normally wouldn't make when not under the pressure of an exam. They try to trip you up by specifying 2.5mm singles on the ring final, but specify a 1.5mm cpc. Just an example. The information is all there, but as i said, when under pressure, it's all too easy to just glance and grab the 2.5mm green and yellow.
When I did mine, I tie wrapped the FP200 to the tray, then when I looked over at another candidate's booth, I remembered. I knew, but i just pure forgot as my heart was beating out of my chest and I wanted to puke. I had just paid nearly a grand and really wanted to pass!
All the literature is provided for you. I took in my own and we had to surrender it incase of cheat sheets etc. Apart from that the whole things a joke.
pirahna nuts are not as good as a banjo and 6mm brass bolt and nut (dont use roofers, they have pressed heads so can pop)
You're going to have to explain that one!
How many sparks are removing the powder coating underneath the banjo? A job that a correctly installed piranha nut will do. That's why they only have the teeth on one side. The other is for plastic enclosures. When tight, do up the grub screw and jobs a goodun!
How is that trying to trip you up? Calculating the size of cpc for such a circuit will almost always come out at a 1.5mm cpc so shouldn't be much of a surprise that 1.5mm is specified
Why do you need to remove the coating under the banjo?
he is a fool.
with a banjo you are using a nut and bolt to carry the current, i dont even know what coating he is talking about? we were talking about using it on plastic
Definitely not a fool dude!
Powder coating on metal DBs is non conductive. The teeth remove the powder coating to earth the armour, or else you need flying leads. Use the non teeth side down on plastic enclosures.
Powder coating on metal DBs is non conductive. The teeth remove the powder coating to earth the enclosure. Use the non teeth side down on plastic enclosures.
first of all we were talking about plastic.
second it is bolted through from the outside of the board with the gland directly on it so it doesnt make a difference as there will be a flying lead from the banjo to the earth bar anyway
Most metal DBs have removable gland plates which are held in place by half a dozen small screws. Unless you have run a flylead to the gland plate then you cannot rely on that for your earth connection.
And you use the p nuts with the teeth facing the enclosure on plastic too, it holds the nut in place whilst you tighten the gland in to it, this should be detailed in the instructions for the p nuts
You should always fly lead the SWA to the earth bar IMO.
I did not know that. In the early 2000 they were done away with in favour of the NVQ
Are you saying the AM2 was 'done away with'?
Although not sure, I don't believe this is/ was the case.
The AM2 has been 'incorporated' into the NVQ 3 (at least when I did it) so that I had to complete the site diary and the AM2 and have an employer's reference to get the Gold Card.
However, as we all know, things are in a constant state of flux regarding the requirements for accredited qualification; it's hard to keep up!
Maybe not done away with but my college would not let us do it as they said it would be done away with. Just done my NVQ and never looked back to find out. Sorry if I was incorrect.
That is one reason the piranha nut was devised as a time saving solution. The 'Piranha' bit was the 'teeth' that 'bit' through the insulating powder coating thus utilising the metal frame of a metal enclosure instead of a fly lead.
I heard all this before with the Orbix fixings only to be told now they are not acceptable as an earth.
USA
United States of America
Manufacturer / Distributor / Supplier / Inventor - etc
2357 am2
shanky887614,
shanky887614,
