239-1 questions | on ElectriciansForums
Discuss 239-1 questions in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
vbyrne
Planet Earth
Lads I have a question that I am not sure about
Why does a calculated result work out much greater than the actual measured result?
Why are type D breakers utilised on certain circuits
if you are referring to Zs readings. the measured figures are generally lower due to parallel paths through the gas/water bonding. and type C and D breakers are used where the switch-on current is excessively high.... transformers, motors etc,
Reply to 239-1 questions in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
thanks, will try that in a few weeks when we're next out in our van
