P
pinball25
hi all
im thinking about doing 2391 and was wondering if it an online exam or written .
if it written is it open book or close
and are there any good areas to read up on
thanks chris
learn gn3 over and over again as phil says and the thread he has recommended as i used this also for my 2391 amberleafs threads are a great help
memorandum of guidance on elecy at work regs
GS38
practice earth fault loop paths for all systems TT ,TN-C-S, TN-S, IT
cristopher kitchers practical guide to inspection and testing
part 7 regs special installations or locations
learn how to write out all required tests in bullet points
practice calculations for resistance of different csa of cables
volt drop
learn the certs and refer to gn3 for filling them out correctly
Gn3 is the main area to focus but revise everything you can and use correct terminology for everything hope thats of some help ad good luck mate
Upvote 0
Best advice I can give is get as many past papers as you can and make notes of them. You usually get the sane sort of questions coming up and similar senarios. I.e. Volt drop, form filling questions, earth fault loop path, a test ring final circuit or insulation resistance etc
Upvote 0
Electrician Courses : Electrical Quals
Thread Tags
pinball25,
CRAGS,
Electrical Courses
