View the thread, titled "240V LED indicator in fan circuit" which is posted in UK Electrical Forum on Electricians Forums.
I have installed an inline bathroom fan with timer plus lighting pull switch and isolator switch. I have also fitted a 240V LED indicator across the switched live and neutral circuit. This works fine except there is some feedback from the fans switched live circuit when the pull switch is in the off position (fan still running on timer) as the LED faintly glows. Any thoughts on how I can fix this or is it to be expected?
This LED indicator has been fitted in case I forget whether the pull switch is on or off (as the fan will continue to run either way).
The simpler way would be to use a double pole pull switch with an indicator lamp. This will switch the neutral to the indicator as well, so stopping it from lighting.
I have done this many times with DP grid switches plus neon, controlling bathroom fans.
Reply to the thread, titled "240V LED indicator in fan circuit" which is posted in UK Electrical Forum on Electricians Forums.
Cumbria
United Kingdom
If other, please explain
Retired Telecoms instructor
UK
Thread Tags
Gabler,
brianmoooore,
