240v Switchboard in Campervan | on ElectriciansForums
Discuss 240v Switchboard in Campervan in the Australia area at ElectriciansForums.net
Yakko69
AUSTRALIA
Hey everyone, new to the forum and was hoping for some advice.
I'm planing the 240v install on my Toyota coaster camper van and am trying to figure out the switch board. I will have a main in from a campsite hook up and also an inverter from the batteries. I want to wire it so that the air conditioning unit, the hot water service (caloifier) and leisure battery charger (forgot to add charger to diagram) are only ever powered off the main hook up. The outlets will be powered by both Inverter and mains via an automatic swichover (32A AC Automatic Crossover Switch - https://sterling-power.com/products/automatic-manual-ac-power-selector-switch).
Would someone have a look at my attached drawing and tell me if:
A) it'll work
B) All the breakers are necessary
C) it's up to code.
Thank you in advance!!
  • [ElectriciansForums.net] 240v Switchboard in Campervan
Reply to 240v Switchboard in Campervan in the Australia area at ElectriciansForums.net
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
