L
Lukasz Cupa
hi guy,
i have an old oil filled heater with an analogue timer on it which is not working so i was thinking if there is a way of swapping the wires on it to bypass the trippers and make it not use the timer is it is equipped in a thermostat too so not really necessary for me to keep the timer
after taking of the cover and pulling out few bits and pieces this is what is stamped on the timer
im no electrician but as i understand when the timer gets to a tripper set on ''off'' this just opens the circuit and when it will get to tripper "on'' is closing the circuit
so is there a way for me to just change the connection of wires to go around the trippers ?
thanks
thanks
