24V contact(component) that switches 230V | on ElectriciansForums
Discuss 24V contact(component) that switches 230V in the UK Electrical Forum area at ElectriciansForums.net
Vyškov Czech Republic
Hi there everyone,
I'm pretty much electrical noob so long story short- I would like to know, if there is a component that is powered by 24V and it sets (contact) 230V on and off.
For example: I have a motor that needs 230V and this 24V component is connected between power supply and motor. I power up this component with 24V it sets the route (turns on like a contact) between power supply and motor (meaning 230 V will run through that 24V component) and motor starts running. When I turn it off (24V component) motor will turn off.
Hopefully my explanation was is ok.
Could You please give me advice?
Thank You Very much
Reply to 24V contact(component) that switches 230V in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
Good one . Thanks. I was finding Fluke etc ÂŁÂŁÂŁ!
