24v DC driver for LED lights. | on ElectriciansForums
Discuss 24v DC driver for LED lights. in the Lighting Forum area at ElectriciansForums.net
London
Hi all,
Can anyone recommend a decent 24V DC constant voltage LED driver.
It’s for an install of bathroom niche LEDs IP65 downlights. They are mini and have a 35mm cut out. The 1.5mm T&E is already dropped to each cut out but need a driver that will fit through a 35mm whole and to be pushed up.
Many thanks,
Jay
Hi all,
Many thanks,
Jay
google tridonic led drivers, go to the tridonic website , find the right one for the power required and check the dimensions, get product code and order through your favourite supplier
The cut out is 35mm but what about the width of the downlight with the bezel? You can gain maybe a few more mm so you could possibly cut a 40mm hole instead, just saying...
Reply to 24v DC driver for LED lights. in the Lighting Forum area at ElectriciansForums.net
Thank you so much for your help I appreciate it alot. I learnt alot and saved alot of money in the progress kudos. Best wishes to you too.:bowing:
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
