W
wing nut
I need to upgrade tails to 25 mm but I have to negotiate a gas pipe. The pipe is 25 mm off the wall and is a plastic pipe inside an old metal pipe. The tails need to go over or under the pipe. ( current 16mm tails do just that )
What I would like to know is, do I need to give mechanical protection to the tails as it is so close to the gas supply or is the double insulation of the tails enough.
