25mm SWA!! | on ElectriciansForums
Discuss 25mm SWA!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
SparkyDips
hello guys i overheard a conversation last week about a supply to an outbuilding which will comprise of: 45A Shower, 32A Ring Final and 6A lighting. Total demand = 83A.
outbuilding is 28Mtrs from main house and will have no extraneous conductive parts as the water feed will be plastic.
now the spark was saying that a 25mm SWA buried in the ground will need to be run and can use the house main earth.
whats your thoughts on this guys??
regards
10mm is well adequate. the guy is talking through his arse. has he not heard of diversity?
25mm swa seems abit over the top to me. Doing a rough calc, 83A x 0.4 = 33.2A. Do some calcs and you will know what size cable you need.
Although I useally take out the biggest mcb, then add the rest, divide by 4 then add the biggest back for your total. This gives a slightly higher demand but still no need for the 25mm swa.lol
sorry, jay. you need to allow 45A for the shower, the 0.4 of the rest. that equates to around 60A.
then again that shower may not pull over 40A . manufacturers are overly optimistic with their figures.
I wonder which is the right way of working out demand?? I do the same by taking away the biggest mcb and adding it back to the total but I was tought to divide by 4. I know alot of lads multiply by 0.4. I suppose doing it the multiply by 0.4 way will give you a slightly higher demand and air on the side of caution!!
Funny how the question is always asked in the 2[SUP]nd[/SUP] inst. It’s never I think it should be what ever, but my friend thinks it should be……….
Funny old world. Or am I a cynic?
a lot of confusion arises over the fact that while a MCB may be 32A for a socket circuit, say, the actual load of the circuit may never get above 20A, sometimes even a lot less if it's not a kitchen RFC.
too late for calculations Tony!! Saturday night is beer time! lol
with this sort of attitude its no wonder people are put off making a post!!
its not a kitchen, will be a small gym comprising treadmill and rower. with shower.
i have been doing the comms cabling and just overheard this conversation.
Reply to 25mm SWA!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
totally agree
Sounds more positive.
