2G Socket - Dual Earth Connection | on ElectriciansForums
Discuss 2G Socket - Dual Earth Connection in the Australia area at ElectriciansForums.net
A
ash_s3
Quick question, just wanted to see what others think about this.
Working on a job at the moment in offices, wiring and connecting sockets in dado trunking.
Was pulled-up today for connecting the two earth cables in the same terminal on the back of the dual socket.
Was told that each earth should be doubled back and terminated in individual earth terminals on the back of the socket. (MK sockets with dual earth)
However when i had a look at the back of the socket, the two earth terminals are joined together anyway.
Didnt want to question his knowledge but just thought it was a bit 'picky'
Was i just being 'put in my place' or is there a reg regarding this? Cant seem to find anything myself.
Anyone got any thoughts?
More than likely high integrity earthing as it is in an office. ie split cpc's at sockets and cu / db.
Is it a ring or a radial circuit?
607-02-05 Where two protective conductors are used in accordance with Regulation 607-02-04 (iii), the ends of the protective conductors shall be terminated independently of each other at all connection points throughout the circuit. e.g. the distribution board, junction boxes and socket-outlets. This requires an accessory to be provided with two separate earth terminals.
Ah ha!
Ring, wired in 4mm T+E
It is in the regs--- somewhere.
A lot of office blocks and office refurbs etc should now be installed this way.
Ill see if i can find it.
Edit Found --- 543.7.1.4
Not sure where you got your reg number from:confused:
Reply to 2G Socket - Dual Earth Connection in the Australia area at ElectriciansForums.net
Thanks Brian. I'll keep doing it then, no harm I suppose. I am lucky in that being DIY, I have the luxury of time when it comes to this kind of...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
