2gang 2 way switches | on ElectriciansForums
Discuss 2gang 2 way switches in the Australia area at ElectriciansForums.net
sparkyb2
can anyone please help me i have in my living room 2 2 gang 2 way switches to operate my 2 living room lights and my missus wants 2 brass 2 gang switches fitted and on temoving them the wires came out of the switches. the set up in the back box is 2 3cores in each switch with the yellow and blue with red tape on each core and a 2 core cable with the black core sleeved red, can anyone explain to me how these should be connected into the switch please.
First switch left side (3 terminals):
com = red (from 3 core)
L1 = blue (from 3 core)
L2 = yellow (from 3 core)
also in same side
com = red (from two core)
L1 = black (from two core) (com and L1 terminals will now have 2 wires each in)
otherside of switch
Other switch same but other way around with 2 core on other side.
also in same side
otherside of switch
I think you may be wrong mate.Red into L1 and Black into L2 from the 2 core.The rest is fine.
Reply to 2gang 2 way switches in the Australia area at ElectriciansForums.net
brilliant thanks for your support. Lee
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
