2KV Wind Turbine Troubles... | on ElectriciansForums
Discuss 2KV Wind Turbine Troubles... in the Australia area at ElectriciansForums.net
B
boersy
Hi.
Please help with my hawt. It's a 96v 2kv turbine and feels like there is to much magnetic resistance. It does not want to spin even when all 3 wires are disconected with no load in very windy conditions. I have had tested the windings and the slip ring and were ok. The bearings are all good and full of grease as is the tail vein in straight condition. I should also add that the bladed are the correct way too.
I did notice the turbine developing a humming sound and could be felt through to tower and became slower and needed more wind to start but now it will just turn with out making power.
Any help is appreciated. thankyou
Sounds like bearings have disintegrated internally if it's still tight with the windings open circuit and isolated. The problem getting progressively worse over time and a humming noise detectable as a vibration thru the tower also points to a bearing mechanical failure.
Hey Marvo
Yeah i have checked them so it's not the bearings. There are 3 bearings for the blade rotation assembly and i have inspected and packed all full of new grease. I feel as though the humming noise was from the magnetic field?
If you've dismantled it to service the bearings you would have noticed any other mechanical failure so we can rule that out. You say you've tested the windings and checked the slip rings so that rules out the internal electrics. You also say it's still a problem with the 3 wires disconnected so that rules out that it could be running to a short circuit or getting reverse fed induced voltages back to the windings. The problem is I can't see anything else it could possibly be that's causing the problem.....you've ruled everything out.
If you're 100% certain that it's not mechanical failure that's causing the problem them I'm leaning toward a winding or other internal electrical fault. What tests did you perform on the windings? What instrumentation did you use and what results did you get?
Well i took the dismantled turbine to an auto elect. I wanted to see if the windings had a break were earthed to the body but after testing the 3 wires individually it was ok. not sure what the tester was called though. Thats why i found this site becauce i have tried everything and needed to here from other people so thanks for your input.
There is never any probs with windmills, the wind always blows at constant...this is free power, bloody-ell whats the problem. Take the juice and dupe the tax payer, then you are green. If any probs blame the wind...lobby your mp and tell him/her....save a polar bear
Soz, i always thought windmills were super efficient (although they are not) and thought maintenance was 0 ( although they are not) ....anyhow keep importing big magnets and batteries, then in 20 years we can all have an acid bath
Reply to 2KV Wind Turbine Troubles... in the Australia area at ElectriciansForums.net
