C
claret73
More than 1 way to skin this cat & so wondered what you all thought?...
The customer is having fitted wardrobes & they need to move the position of 2x sockets to become accessible. It is a top floor flat with access above. Thoughts are:
1/ Chase out (unnecessarily) the existing drops & reloop the ring correctly with new legs.
2/ Join existing socket legs to new legs for each socket with a crimp joint inside existing box & blank off with a plate. Providing this does not interfere with fitting of wardrobes. Just thought in the unlikelihood of having access to the joint it's easier than chopping out the wall.
3/ If above is an issue, crimp joint & bury directly into wall...
