3 core flex. | on ElectriciansForums
Discuss 3 core flex. in the Australia area at ElectriciansForums.net
B
Bright.Spark
I'm adding a outside light to an. Existing install. The lights have been wired in an rb4. Can I add my light fitting to the circuit but wire it in 3 core flex instead of 1.5 twin and earth?
I always use black 3 core flex because I think it looks neater than having T&E on the walls and as Nick says, the cable glands on most fittings are designed for round cable.
It’s unlikely to get damaged when wiring at high level such as installing a light, however, if flex or hi tuf etc is routed at low level where it can be damaged it should certainly have some form of mechanical protection.
ian
pvc flex = no
rubber = yes
You are going to have to convince me of that. i have read the technical specs on flex recently and it does not say it cannot be clipped outside.
If we were discussing grey T&E i would agree because it perishes in direct sunlight, but black or white flex, there is no problem with.
ian
Reply to 3 core flex. in the Australia area at ElectriciansForums.net
As you've found out, there's capacitive coupling between cores which will induce a voltage into other cores when one (or more) is fed with AC. How...
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
