3 core t+e giving 45 volts when off | on ElectriciansForums
Discuss 3 core t+e giving 45 volts when off in the The Welcome Forum area at ElectriciansForums.net
mick b
bolton
I have a 3 core t+e on a 2 way switch and when it is turned off there is still 45 volts at the light. I have stripped this down to a 1 way switch and the voltage disappears. I then meggered the 3 core and it is clear. There is continuity through the conductors and no obvious fault with the cable. The earth is connected but when I put the cable back on it goes to 45 volts again. Any ideas on induced voltages on 3 core cable.
Many thanks
If you do the same test with a real mans voltmeter ie one with a needle instead of a digital display I bet there's no significant voltage
There's lots of threads around about the ghost or phantom voltages being a problem with the high input impedance of digital testers.
It's not induced. Copper is non-ferrous remember, you can't induce voltage copper to copper. The problem you have is capacative coupling, it is a phantom voltage and is harmless. Use an analogue multimeter and it won't register.
The most likely cause for this 'problem' for want of a better word, is degraded insulation.
Yes you can, induction occurs in any conductor if it moves through a magnetic field, or if an alternating magnetic field crosses a conductor.
You can't create a substantial magnetic field with a non ferrous material. Think! A ferrous material is needed to focus the induced magnetic force from one conductor to another :)
To induce a current in a copper conductor you need; alternating current --> copper --> ferrous material --> copper
If you want to induce measurable current from copper to copper, you would need miles and miles and miles of conductor with a gap between them so small it would be almost invisible to the eye! Even then you'd be talking microamps!
When I say you 'can't', what I really mean is that it's really really hard!
I've developed a high impedance to these questions now, that's why I don't respond to them anymore.
I might give a false answer.
The frequency of this particular question does point to an across the board lack of understanding in this particular area. It's obviously something that's not being covered properly in the training and I'm not convinced it's just the limited scope training that's at fault here.
Reply to 3 core t+e giving 45 volts when off in the The Welcome Forum area at ElectriciansForums.net
I think a 3 legged breakout boot would be your best bet in the circumstances.
davesparks
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
