M
minstercourt
Hi, im a newbie here, so please excuse me if any mistakes in my post. i have a 3 gang switch on our living room. in them three switches on switch is used for the living room light which works fine, another switch is a two way switch which operates the stairs light which has the other 2-way switch is upstairs, even that one works fine. the third switch is for the light outside the house, which is not working. i have changed the bulbs, holders and i have checked the current passage with a tester and its getting the power but still doesn't work. if i use the same bulbs and holders some where else it works. can you suggest me, how can i sort this out. i am adding a picture of the switch connections to this thread, i think its not clear but let me know if you need some more detail. Thank you for your help.
