3 gang switch | on ElectriciansForums
Discuss 3 gang switch in the Australia area at ElectriciansForums.net
sim22
Little project to start the new year off, looks like I'm going to have to change a 3 gang light switch which controls front room light (area around switch is crumbling ),outside light + porch light.
All sounds pretty straight forward apart from the fact that one switch has never worked since we moved in to house,operates porch or outside light ( need to investigate which ) best guess is outside light cos it looks pretty grotty.
Any advice on best way to proceed ?
I am not qualified but also not a complete novice ( half way through 2330 year 2 ) but understand the reasons for doing things properly + safe.
Before you change the light switch that's already there test to see if that's where the problem is first. Also make sure you carry out & prove SAFE ISOLATION before working on the wiring.
there is a problem or problem or problems with the switch, one has never operated (will not move), one works fine + one is connected to the porch light, yet to be tested
Hello,
Get Colin reed round from Sheilds, here he is the boy to sort this problem for you m8.
Can't cos its not on the roof lol so solar colin is no good
but feel free to come round + assist, then when I cock it up it'll be your fault for not stopping me :hammer:
:46:
gonna speak to neil next week see if we can make it a field trip
If I don't speak to you before have Happy New Year:party: + try not to get too bladdered :54:
DS will sort it!
As mentioned, label all conductors and refit accordingly.
Remember different makes of switch lable com/l1/l2/l3 differently and put them in different places on the switch.
Reply to 3 gang switch in the Australia area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Smart switch 2-way operation is often achieved by the second "2-way" switch actuating the first "2-way" by RF (the first actually doing the...
