3 phase 4 wire Neutral Calculation. | on ElectriciansForums
Discuss 3 phase 4 wire Neutral Calculation. in the UK Electrical Forum area at ElectriciansForums.net
A
Andy1
Hi all,
Im still in apprentice stages of becoming a sparky and currently learning allot about 3 phase at college the moment. Can anyone share their knowledge with me on how to correctly calculate the Neutral current on a 3 phase 4 wire star system when there is an imbalance between phases
e.g L1 = 50 amps, L2 = 40amps, L3 = 30amps?
Im a bit unsure on the correct way to calculate the Neutral current.
Thanks for your time and help.... Please be gentle I'm still learning :)
Andy.
[ElectriciansForums.net] 3 phase 4 wire Neutral Calculation.
Reply to 3 phase 4 wire Neutral Calculation. in the UK Electrical Forum area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
