3 Phase board pics | on ElectriciansForums
Discuss 3 Phase board pics in the Australia area at ElectriciansForums.net
sparkz
Anyone got any pics of 3 phase boards. Just need to get some idea's on how to form the cables into the terminals. Would like to see how much slack and how you keeps the cables together e.g cable ties (yes some may disagree but iv seen ties used before).
Appreciate your help
Look on some manufactures websites they usually have a few pics with them installed with the cables inside. Oh and if you want the same affect as using cable ties for keeping cables tidy. Whilst installing the board,cable tie all cables into final positions once tested energize, If your on the job for a couple of days last knockings cut all the cable ties, the cables should have stiffened slightly and keep the rough shape you intended. The bigger conductors will stay in position without cable ties.
I never cable tie. Depending on the board I sort of run the earths and neutrals on the far edges. The phase wires I manage to half tuck them behind the mcb's and form a little loom with them. As for length I go past the terminal I want to connect by about 3 inches and then go back up into it. Is this making any sense?
But I never Leave loads on them. That causes real problems for someone who has to work on it afterwards, as Ik sure you all know!
Domestic single phase - but same approach
  • [ElectriciansForums.net] 3 Phase board pics
thats the older hager board isnt it. the new ones' are kinda crap (no proper incoming neutral point), plus im suprised its not full of rcbos?
other than that yeah id be happy if my board looked like that.
im doing a 2nd fix on a 16 way 3ph hager board next week (v big house) if i remember ill get a photo up here.
I want to know how that paper stays up too.......................
How sad is it that I looked at that and thought WOW that looks great, next thing you know I will be collecting MCB model numbers............................................
VERY nice!!!
SHOW OFF!
Reply to 3 Phase board pics in the Australia area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
