Discuss 3 phase circuit in the Electrician Talk | All Countries area at ElectriciansForums.net
I'll second that - what is it with more that one outlet on 3 phase radials and even worse rings at the mo!
3 phase outlets or 1 phase outlets, all have to be designed and installed as to be fit for purpose...
So why is it a problem for you to have more than one outlet on a 3 phase radial?? Is there something different about the basic rules for 3 phase outlets to single phase ones??
Design the overall circuit right for the application and usage it is intended for, and there shouldn't be a problem!!! I'm not saying that every 3 phase outlet radial can support multiple outlets, that very much depends on it's application....
Bus bar tap off's are fused, ( except lighting ), and what would the consequences be if a machine takes out the ocpd and someone else is using a woodworking machine or something simular, I just think it's bad practice ok for small workshop with 1 op in it but apart from that I think it's pants unless every point has its own fused isolator
Reply to 3 phase circuit in the Electrician Talk | All Countries area at ElectriciansForums.net
