B
bal
Hi,
I'm a technicain in a factory tasked with the following. I am currently looking into consolidating our electricity feed. We have several 600 amp fused isolators which are under utilized ie we have small feeds coming off these.
To this end I am thinking of implementing the following. Use a single 600amp isolator to feed a 600 amp busbar. This would then be used to feed to 3 x 200 amp fused isolators thereby emptying several under utilised 600 amp isolators for other applications.
Firstly is this the best way of splitting a 600amp feed??
Secondly as the above will involved some recabling work I think that some of the armoured cables may be short and its not passible to replace the whole length of cable. What is the best safest way of extending them. The all are housed indoors.
Any thoughts would be appreciated.
regards
regards
