3 phase generator questions | on ElectriciansForums
Discuss 3 phase generator questions in the Australia area at ElectriciansForums.net
Some clarification please guys.
Got called out today to wire a 3 phase 32amp Socket into a Builders own 3 phase Genny - (ex AGrreko, bought at auction). Needed to supply a 3 phase plasterers pump system. The genny only had 2x 16amp 240v outlets.
So, opened panel, there was stud terminals L1, L2, L3 & N. Had prewired a board with small CU feeding a socket with 6mm tails coming out. connected these onto the terminals. Turned on pump - nowt.
To cut a long story short, testing with both martindale neon tester & Digital tester showed between 215/220v on all L terminals to N. So far so good. L1/L2 or L2/l3 or L1/L3 all 0V (expected around 415). Coming out of the N terminal was a 10mm earth wire secured to the body of the genny. when I test across this Earth terminal & any L, or for that matter N, then I get 110v which confuses me.
Can somebody explain how this works please?
btw once I worked out that L1/2/3 were the same phase (knackered genny obv) the builder hired a replacement, connected same way to new one and off we went. 10 minutes to do that. 4 hours between connecting original & waiting on replacement.
Its 6 foot long, 4 foot high & wide and with L1 L2 & L3 & N terminals I'm sure it is/was. should also have said that where the data plate was - can see the outline & the 4 rivet holes - someone has scratched "1 phase" which suggests its been adapted at some point. But anyone explain to me the readings I am getting - is this normal for a generator?
The alternator may have had it's tappings altered to provide single phase output (Which normally is a higher rating for a single phase, than the 3phase, per phase, rating). You may just need to adjust it back to 3-phase, and you should be able to ring the alternator manufacturer and they'll tell you what needs to be done. It's a relatively simple job to do IIRC.
http://www.dieselserviceandsupply.com/Generator_Phase_Conversions.aspx has a reasonable description of what's involved.
Reply to 3 phase generator questions in the Australia area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
