hi all,
a local factory has had a new machine installed which meant their system couldnt handle the load so i installed a generator on the warehouse to run this separatley.
upon monitoring their current usage i noticed phase 2 to always be high, in some case peaked at 80 amps difference between that and the other 2 phases. This obvioulsy creates and imbalance within the 3 phase system and machinery, this results in 'wasted' current. is this difference big enough to cause a lot of potential 'wasted' current? as their supply is only 500amp and they are running close, just trying to delve in to as why they seem to be running so high.
hope this all makes sense!
