J
jmsparks
I am installing a 3 phase hose swaging machine, just want to run through the install make sure i have it right, any suggestions welcome. i have been told it will require a 30a 3 phase supply
32A 3phase breaker type c
4mm 3core SWA
From the board, wire to a 32a rotary isolator in 4mm swa, using the armouring as the earth.
From the isolator to a DOL starter,(green on and red off button) in 4mm singles in 20mm plastic copex.
From the DOL starter to the machine, using the lead supplied witht he machine in plastic copex.
Questions...
Does the DOL starter act as a sufficient emergency stop button?
Is it better the wire into a commando outlet so the machine can be changed?
4mm 3core SWA
Questions...
