sparkie-leeds
Hi All,
The electric board are installing a new 3 phase supply in to the building, they are asking for a 3 phase isolator which is not a problem. From the 3 phase isolator i am running a 4 core 25mm armoured cable with seperate 16mm cpc to a mains board. What i want to know does the 3 phase isolator have to be FUSED, the incoming fuses are 100amp supplied by the elctric board in the main head.
The isolator will be rated at 100 amp aswell.
thanks.
thanks.
