M
mishmash
Hi guys
Am new to this forum and this is my first post!
Have done some industrial work before but never on the scale of the job I'm about to start.
I need to install 2 new 100amp distribution boards in a unit, both are about 20 meters away from the 3 phase supply and current distribution board. I'm intending to feed the boards with 25mm 4 core swa and run separate cpc. Each of the new boards will also have a 100amp switch fuse due to the long cable run.
My problem is identifying the kit I need at the supply. I've been trawling the web for some sort of 400amp switchfuse from which I can then run 3 sets of tails out to the 3 distribution boards.
Am I barking up the wrong tree here? Any help much appreciated.
