Evening Gents,
I have been tasked at work to install a 3 phase meter measuring power usage in a commercial kitchen area.My question is - Is there are a product out there which can be permanently clamped around a three phase cable which provides a digital display and will provide, a record of kw usage and will record , daily/weekly monthly usage . I doubt if there is a item of this equipment available but hey ho you never know.
Cheers
Sparky 63
Evening Gents,
Cheers
Sparky 63
why not chop into board supply and put a 3ph meter in.
smart meters have the features you seek so your friendly local wholesaler should be able to get one
Evening Gents,
Cheers
Sparky 63
Yes and they are very common, try google, a wonderful tool, I bet it will take seconds to see what you are looking for.
Hi there, I was trying not to chop into the board and rather try to adopt a system that works on toroidal transformer being wrapped around the cable, and the currents being induced into the metering
Hi Dave does this equipment require a direct electrical connection to phases ?
It requires batteries and the rest is done with CTs, you just have to program the supply voltage and any other parameters you need.
I used this as a rudimentary way of monitoring a generator at a festival a couple of years ago.
Should do the job, there are clamps which go around the cable without actually having to disconnect any wires, the instruction download should tell you more.
3 phase metering
Sparky 63,
Sparky 63,
