3 phase motor over current formula | on ElectriciansForums
Discuss 3 phase motor over current formula in the UK Electrical Forum area at ElectriciansForums.net
Cardiff
the apprentice is sitting his am2 and question is on his 3 phase motor which is 5.5kw what is the over current he dont deal with 3 phase what's quickest way to explain to work it out
Are you asking what current a 5.5KW would take? you should be able to help him there Scott.
Hopefully this will help.
[ElectriciansForums.net] 3 phase motor over current formula
I think the trick here is that they aren't given the flc for the test, only the motor power rating (it's not a real motor IIRC, just a terminal box). But on the basis of post #6 the power quoted is not given as normal on a motor (output power) but the electrical input power. Or whoever wrote that suspect-looking page was even more barking.
Reply to 3 phase motor over current formula in the UK Electrical Forum area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
