The supply is is a 3 phase 100 amp per phase, each phase is drawing 50-55 amps in normal day to day running already without the said 55kw motor, the motor would be no more than 10 meter away from the main DB with the Y/D starter situated halfway between the main DB and the motor all cables would be run on tray.. The info plate on the motor says it draws 96 amps and the calculation in my original post clarifies that,
this is why i asked is this 96 amps per phase or if it would be divided between the 3, so i could then work out what size cable and circuit breaker would be used by referring to the relevant tables in BS7671, i myself would have assumed it would be somewhere round 25-35mm cable (swa) and would be fed from a 96 amp 3 pole type C breaker and i was also thinking that the supply was not big enough. this said i do only have limited knowledge i did the C+G 2351 and NVQ level 3 in electrical installation in 2003 along with what was then the 16th edition since then i have updated to the 17th edition + part P and completed a fire alarm and emergency lighting qualification, the person i work for has the same but has completed the 2391 inspection and testing so its not something either of us is capable of doing with our knowledge, i just wanted to find out for my own piece of mind if had worked it out right hence why im asking on this forum.... if ive not provided enough information i can try and find out a bit more, and can only give you my word that this work would not be attempted by me on the advice from this forum, i would always make sure id got relevant qualifications and referred to the relevant material in BS7671 before carrying out any work not just take someones advice from the internet...
while i was looking for info on the subject i came across this link :-
What is cable size for a 55kw 3 phase induction motor 10 metre run for cable 415v
Which is the reason 70mm was mentioned ??
Anyway thanks again for all your answers and if anyone does know the proper way to go about working it out im all ears or info on what course or qualification you would need to do this type of work even ??
Thanks again hope to hear back...
