3 phase on a domestic property | on ElectriciansForums
Discuss 3 phase on a domestic property in the Domestic Electrician Forum area at ElectriciansForums.net
Z
zodiacspain
I have recently bought a property with 3 phase electric supply, 3 phases and a neutral, we are turning the house into 2 apartments, so would it be possible to put 1 phase to each appartment and then the last phase to the garage? i know that when each phase is connected to the neutral it is 240v.
I'm not an electrician but i have alot of common sense, i have read that you should load each phase as evenly as possible, but this not be possible with the way i would like to use it.
Can anyone answer my question and help?
Gary
you would have to calculate the load on each phase. taking diversity into account, and balance as best you can. but bear in mind that this work needs to be done by a qualified electrician.
There are many properties with 3phase supplies, that only use one or two of the phases.
Is the garage intended to be metered separately to the two apartments, or is it intended for the garage to be metered with one of them?
I'm in Spain and electric company in Spain is Iberdrola, they have fitted a 3 phase meter, so coming out of the meter is 3 phases and a neutral ... the apartments will be one for me and the other for a friend so all we've decided to have whatever the bill is, so each apartment does not need to be metered separately ;)
we have 3 phase over here in corfu as well as the single phase supply is only 10kw. now what we do is put in a type of henley block or fuse bd by the meter and take a seperate 3 phase supply to each place when it does not need to be metered. this trying to keep the balance. however greek sparks don't seem to see the potential of 3 phase and will put put it all over the p[lace rather than seperate rooms etc.
we have 3 phase over here in corfu as well as the single phase supply is only 10kw. now what we do is put in a type of henley block or fuse bd by the meter and take a seperate 3 phase supply to each place when it does not need to be metered. this trying to keep the balance. however greek sparks don't seem to see the potential of 3 phase and will put put it all over the place rather than seperate rooms etc.
What's the problem with that?? A simple solution would be to use the phase colours for the live conductors, same as i insisted on for my house in Cyprus. I certainly wouldn't be arsing around having different phases for separate rooms, the circuitry alone (and conduit runs) would be a nightmare, let alone trying to maintain any form of load balancing!!
when i bought this house, the previous owner worked for the electric company in Spain, all I can say is the house has been wired with wire that could run Blackpool illuminations LOL ... each phase has a big 40amp 400v fuse, thank you everyone for your comments, i will also be asking an electrician to come and have a look, thank for those who answered some of my questions :)
Oh god, I can imagine what the wiring is like! The meter cupboard in my first house looked like an extension to Battersea power station :eek:mg_smile:
LOL .... the main power board was full of fuses and spaghetti wiring, looked like something from Einstein with bakelite switches and sockets, and this was last week :/
Reply to 3 phase on a domestic property in the Domestic Electrician Forum area at ElectriciansForums.net
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
Three phase or single phase it is not correct.
