imnvsh
Thank you for your time ? I have an oven that connecting directly to the 3-phase source (3N in the pictures below).
However, this is quite annoying, because the oven is fixed close to the source. Hence, I would like to know whether it is possible to wire as 1N instead, i.e. wiring the device's L1, L2, L3 together and then use an 1-phase source instead with the below cable. Thus, I could move the oven around and plug it for my use in any corner.
I am a bit worry about the 11,4 kW power of the oven. Could an 1-phase source provided on the wall in Germany reach that power? Let's say 230 V, so a current 11,4 kW / 230 V ~ 50 A is required. I guess that all 1-phase sockets on the wall are also originated from the 3-phase source, which helps to stabilize the electric without a need of an extra "voltage stabilizer".
I am looking forward to reading your discussions and really appreciate your interest.
