A
a1colly
Hi all
This is probably very easy but for the life of me I haven't been able to discover the answer and solution.
Three phase taken to a tpn fused isolator, then taken to a sub meter and split to three spn consumer units (each being sub metered again) The neutral has been taken to a Henley block and split to the three boards and meters.
Phase sequencing checked and correct at tpn meter, and also correct at the spn meters. however upon testing incorrect polarity at all consumer units, despite when testing polarity the MFT says its correct.
I have 210V. L1,L2 & L3 to N. across phases I have 410V and to earth I have 245V. Which seems odd as would expect 245V and my instant thought is a loose neutral connection.
Continuity and insulation checked and all okay. It a TNS system with a reading of 0.18Mohms however when trying to complete a Zs or RCD my MFT gives an incorrect polarity result.
I have checked that I haven't wired up the supply incorrectly for the tenth time but all looks correct. I have left isolated for the night and returning in the morning after a good nights sleep to look at again.
Any help appreciated as my brain is not engaged at the moment.
Thanks and sorry if it is so obvious
