3 Phase query - help!! | on ElectriciansForums
Discuss 3 Phase query - help!! in the Electrician Talk | All Countries area at ElectriciansForums.net
polo1
Glasgow
Ashamed to admit, but my 3 phase experience is limited:blush2:
What would cause me to loose the indication of a phase, when applying a load to that particular phase? It only happens with certain loads.
Thanks.
Sorry, first post was kinda rushed. 3P & N.
I've been getting pulled all over the place on this job and not getting time to do anything properly/methodically.
"Testing" has been simply checking phase to N. When load is applied phase appears to drop out. It's a sub board, serving three lighting and one other (unidentified) circuit and I have not yet found out where it's fed from. A thought, could this be voltage drop, as the sub main appears to be quite small?
Seems like a loose connection, its good enough to give the indication, but when a heavy load is applied the connection cannot carry the current.
Reply to 3 Phase query - help!! in the Electrician Talk | All Countries area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
