3 phase rcd tripping | Page 2 | on ElectriciansForums
Discuss 3 phase rcd tripping in the UK Electrical Forum area at ElectriciansForums.net
DaleRobbo
Hey just a quick one,
The factory I work at have built a new maintenance shed, and each work station has a 3 phase outlet rcd protected. Now, my problem is every time I make up a board which contains contactors it trips the rcd.. Is this due to some sort of balance issue? Can some one clear this up for me?
Thanks,
Dale..
Yes correct a VSD chops up the wave form of the supply and re-builds it as required any any waste is dumped down earth hence the designed leakage.... as ive found a 1.5kw and aove usually is large enough to cause nuisance trippingon 30mA rcd's
Reply to 3 phase rcd tripping in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
