sparky147
I need to install 4x 3 phase sockets and as i havent got much room on the consumer unit, i was wondering if its possible to install all 4 sockets on a radial circuit with a 32amp MCB using 4mm cable running no more than 15 meters. The 4 machines that are going to be plugged in are 2x 6amp and 2x 8amp, also each socket will be protected by its own RCD. The reason im asking is all 3 phase sockets i have come a cross have there own MCB, but as the machines that are going to be plugged in are low amps i was wondering if it was possible, many thanks.
