T
timmy123
I am looking for some advice regarding installing a supply for a 4hp three phase band saw.
I do 99% domestic/office single phase installations however I have been asked by a client as part of a job to do the above.
The saw will run off a 3 phase socket. I am planning to run the supply from an existing 3 phase isolator box which no longer has a machine supplied from it. The isolator box is located some 5 metres from the required socket point. There is no requirement to have any single phase supply associated with the saw.
My main questions are:
As there is no requirement for single phase am I correct in assuming that no neutral is required?
As far as wiring the socket is concerned what considerations do I need to take into account regarding where the L1,L2,L3 conductors are terminated in the socket?. I have not wired a 3 phase socket before
Any other main points I need to consider?
You may say "get a industrial electrician to do this" however I hold city and guilds 2330 level 3 and part P(17th), but just lack the practical knowledge on this.
Any guidance would be greatly appreciated.
Many thanks
Many thanks
