L
littlelectrics
Hi all,
Im sure I'm right, but thought id check.
Ive been asked to wire two flats which are being formed from 1 existing building. The Existing building has just had a new 3 phase supply installed, (i don't understand why). but i only need single phase, but as i have three phase this gives me the option to supply one flat off one phase and another flat off another phase, but is this ok in regards to balancing the phases. i have no use for the 3rd phase. Also if i take 1 phase to each flat this means ill be sharing a neutral :-/. Is this ok? sorry if this is a silly question but not had a lot of dealings with the 3 phase stuff myself.
