A
aldomack
Hi I wander if anyone can help?
I have just wired up 2 3 phase motors on a Farm for a Auger System, I have ran in a 3 phase supply from a nearby J.B. There is only 3 phase wires and the outer armour of the cable connected to the body of the box as the earth on the J.B. I have run these into the Control box for the Auger and connected the earths up and the Phaes L1,L2,L3. These are going into the top of the breaker, BENEDIKT JAGER K2-09A. There is connections for the contactor coil A1 and A2, I require a neutral for the coil to work but how do I get this when there is none on the supply I have run??? hmmm I'm stuck:(
please see attachment
Here are somre more photos, the incomming supply comes in from the left and into the top of the right contactor, the 2 contactors are linked at the top. The Motors are fed from out the bottom of the contactors,
hi
normally on auger systems there are some sort of stop sensor or switch, not sure if you have this sort of set up but if so make sure that it is rated at 400v if using a 400v coil
regards
gary
Cool, can you reccommend any type or part No's for what I require? The Motors are 1.99A x 2 . The type fitted are Benedekt and Jager K2-09A Unit if that means anything?
Yes there are pressure sensors and these are connected, one wire is going to the neutral of the coil. God knows how I will find out if these are 400v rated there are no markings?
best solutrion is a step down transformer, 415/230v. cheapest and simplest. first try the coil with a 230v supply see if it pulls in.
Do the augers feed cows whilst they are being milked, if so , the augers will be controled automatically via a capacitive Senser.those contacters are DOL. the ones I have seen are 240v as the sensors are 240v.
3 phase supply no neutral how do i get neutral for the contactor coil??
Australia
aldomack,
mikehopkins,
