F
funkguppy
Hi.
Looking to pick someone's brain.
In a commercial (formerly industrial) building, i have been asked to run power to a 3 phase lathe. There is a 3 phase board in the vicinity but it's a bit old and has BS3036 fuses. Problem is the fuses are not interconnected, so if one fuse blows, the other two are still live, causing problems with safe isolation and the motor itself. If it was a modern board, i could have fitted a triple pole MCB.
Any ideas as to the best solution?
Thanks.
Thanks.
