I've got 3 roof fans to be wired from 3 spurs fitted on the inside concrete ceiling. They shall be controlled from 3 ground level fan controllers. Supply to the 3 controllers is via 3 conduit drops off the trunking.
My question is, can I run all 3 phases in the one conduit to the spurs (4 control-wires for each).
Up at ceiling level I intend to tube to a Tee-box, to Tee-box then to an Angle-box, then fit the spurs to the conduit boxes thereby removing the possible risk of 415v at each spur outlet.
