3 phase volt drop. | on ElectriciansForums
Discuss 3 phase volt drop. in the UK Electrical Forum area at ElectriciansForums.net
M
mansabadman
Howdy, when designing a 250A 3 phase supply, what column value do you use for volt drop??
Table 4d4b, section 4(3/4 core 3 phase ac) column r,x or z.
I'm thinking r, but not 100% sure. Cheers in advance!!!
Reply to 3 phase volt drop. in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
