I was recently surveying a football stadium and the amplification racks for two of the stands were in one location. The equipment was mounted in 3 separate racks each housing about eight 400 watt amplifiers (real long term power not home hi-fi peak/transient power)
This makes for quite a current draw: at full tilt each rack would probably draw about 15 amperes.
When I checked the electrical feeds to each rack I found that each rack was fed from a different electrical phase.
Commercial amplifiers need a large mains transformer so present an inductive load so I can sort of understand the need to balance it.
My concern was that there could be large potential difference between the racks which could be quite scary - all the racks are next to each other with low voltage and current signal cables running between them.
Is this set-up a concern or am I being overly cautious.
If this is dangerous are there any ways to reduce the dangers without needing to rewire.
Nigel
Nigel
