3 Pin Plugs | on ElectriciansForums
Discuss 3 Pin Plugs in the Australia area at ElectriciansForums.net
Are you thinking of sleeved re-wireable plugs, in that case I would say that it would have 1970's and the MK safetyplug which are still available in virtually the same design? They are the only one that I know that have the post terminals where you have to wrap the wire round a post and then put the slotted top nut on to it.
Maybe even earlier.
I remember using these around 1973.
Reply to 3 Pin Plugs in the Australia area at ElectriciansForums.net
I made some adaptor plugs up when Maplins closed down, I got a job lot of insulated 4mm banana sockets for a few quid and made up a full range...
It is possible that the particular socket you normally use in the kitchen is worn, or there's a wiring issue behind, contributing to the heating...
