3 pole incoming switch | on ElectriciansForums
Discuss 3 pole incoming switch in the Australia area at ElectriciansForums.net
M
markharris
hello guys,
A 100a 30ma TP & N incoming switch for a three phase board.....is that 100a for each phase, or 100a for all three together?
Many Thanks
Reply to 3 pole incoming switch in the Australia area at ElectriciansForums.net
Good point, I was assuming an up-front RCD is for fault protection within DB, etc, and to cover for a failed RCBO for fault conditions, not as...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
