3 pole isolators | on ElectriciansForums
Discuss 3 pole isolators in the Australia area at ElectriciansForums.net
Derbyshire
Hi all,
Got a brainfreeze going on here, is it ok to use a 3 phase 3 pole rotary isolator to isolate a single phase instalation (l+n+cpc) hot tub circuit, i mean L1 as live, L2 as neutral and have L3 spare? :confused:
Thanks in advance..
Reply to 3 pole isolators in the Australia area at ElectriciansForums.net
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
N
In my first sparking era (late 90's) I was always told to run a neutral to the isolator, as the chances are whoever is using the machine will...
